Xibo Player impossible to connect on cms
For start, excuse me for my english, i’m french… :flag_fr:
So, I installed Xibo on my computer with xampp, thus I have a CMS address localhost.
I have make that in setting :
I thus put this informations in xibo player options.
And here is his return :
Status
Le client a trouvé ‘text/html; charset=UTF-8’ comme type de contenu de la réponse, alors qu’il attendait ‘text/xml’.
La demande a échoué avec le message d’erreur :
Deprecated: Automatically populating $HTTP_RAW_POST_DATA is deprecated and will be removed in a future version. To avoid this warning set 'always_populate_raw_post_data' to '-1' in php.ini and use the php://input stream instead. in Unknown on line 0
Warning: Cannot modify header information - headers already sent in Unknown on line 0
<?xml version="1.0" encoding="UTF-8"?> <?xml version="1.0"?> 9001464069600000146412360000011000010IBottom Right110001error20003TEST0
Can you help me ?
Thx in advance ! :relaxed:
The real return :
You will want to open your php.ini find this line and make sure it’s not commented out (no “;” before it)
Thx a lot peter ! :slight_smile:
