I thus put this informations in xibo player options.
And here is his return :
> "Status > Le client a trouvé ‘text/plain;charset=UTF-8’ comme type de contenu de la réponse, alors qu’il attendait ‘text/xml’. > La demande a échoué avec le message d’erreur : > – > There has been an unknown error with XMDS, it has been logged. Please contact your administrator. > --."
Please can you confirm the version of your CMS and the player version you have installed? You can find the CMS version on the login page beneath the password field and you can find the player version in the Xibo player options application if you click the about tab.
Hi and thanks for your response,
my player is v3R0302 and my cms is 2,1.
I was unable to install the newer versions of the cms (I did not understand why, I had to try all versions to finally successed in this one).
Do you have any idea ?
Thank you for confirming the player and CMS version. Xibo for Windows R302 is not backwards compatible, it requires CMS version 3. Please can you uninstall the player and try R258 instead? You can download a copy of the player here.
