Xibo Player Display Different than preview
Comparison of the two
Left is the Preview, Right is the client.
I just started using Xibo to create a dashboard for work (information whited out due to having other peoples information) so, i’m not well-versed in how to use it. Is there a setting or command I am supposed to change/add/delete to make it look similar or do I have to change the layout itself to fit with the Xibo player?
Those are embedded html or webpage media types? We do our best to scale them (depending on what settings you’ve chosen in the media) but ultimately you may have to fine tune to fit the actual display you’re going to use
Xanian,
Looks like tables are being used. My guess is that they have a defined width with PX EM or something like that. I would suggest you change them to a percentage value.
