Xibo Permission
hi,
i created user in xibo 1.7.5 , but i have just the permission for add the new layout without display.
i give all permission for user but without any result
I’d highly suggest upgrade to at least 1.7.9 version.
in 1.7 series, there are menu security and page security.
There is also a dropdown for each menu security.
If user should have permissions to any existing media file, layout or display, then you will need to assign that user permissions to the specific file/display/layout as well.
