Xibo on Oracle cloud arm installation
I have set up a free tier server on oracle cloud (VM.Standard.A1.Flex), 2 cpu - 12 gb ram, 50 gb space arm ampere.
Can Xibo be installed on ampere arm architecture ?
Greets,
Dennis
Hi, unfortunately we are not familiar with that type of hardware, what operating system you can run on it on or its performance so unless a member of the community has anything they could add you will have to try it out.
It would be great if you do give it a try to post your experiences to the community! :smile:
