Xibo is not working
I have installed xibo on windows x64 bit
Docker is running. Xibo has been installed but i am unable to access the xibo on localhost please help me out
I assume you’re using Docker for Windows (and not docker toolbox?)
What do you see when you navigate to the localhost?
In the powershell command line when you type
docker ps
what’s the output of that please?
If that was your first up command, it may take some time on Windows to spin it up, if you’re still having problems please do let us know.
