Xibo Installation Hosting party
Hi
I am trying to install Xibo CMS 7.6
Unfortunterly i get the following Error in the list:
Calendar Extension  x PHP Calendar extension to function.
Does somebody knows why?
In php.ini the function is enabled
Best regards Jan
what web server are you using please?
http://php.net/manual/en/calendar.installation.php
I have tried
5.5
5.6
They all have the same error on the calendar
If i debug i have these messages:
Notice: SQLSTATE[HY000] [1045] Access denied for user ‘’@‘localhost’ (using password: NO) in /sites/jdt-services.nl/uitzending/config/config.class.php on line 78 Notice: SQLSTATE[HY000] [1045] Access denied for user ‘’@‘localhost’ (using password: NO) in /sites/jdt-services.nl/uitzending/config/config.class.php on line 78
GR JAn
I think that sums it up. You should set a password for the user, really all users. To do so you may want to take a look at this:
Hi
I have no acces to my.ini
So i have to change it in the xibo file(s)
Could you please explain to me which file i should adjust?
gr JAn
