Xibo in host (No doker)
The installation has been correct and I accede to the administration through the link: Xibo Digital Signage (I have to add web to my domain)
The XMR configuration is:
When I go to the player it can not connect:
CMS address: http://cartelldigital.gestioperemartell.cat:9505
Status: Unable to connect to remote server
can you help me
I don’t think that you have XMR configured correctly, please see http://xibo.org.uk/manual/en/install_xmr.html
As for web in the url, that’s most likely due to incorrectly configured document root - http://xibo.org.uk/manual/en/install_environment.html
