Xibo in docker installation reg
Hi
I am new to xibo docker installation .
I was using the web server.
Now i installed successfully in docker .
What is the path/cms address i have to give in player .
is it the IP address of my CMS installed PC(ie http://192.168.0.104 /xibo-docker ) or Virtual box ip adress (ie 192.168.99.100/xibo-docker
pls help me
Depends, if you have docker for linux/windows or docker toolbox.
first case - ip of the pc/server on which you have it installed on.
toolbox - docker toolbox IP, which you can get by running docker-machine ip
For more information please see https://xibo.org.uk/manual/en/install_cms.html and the relevant instructions for your environment.
Hi
I am using windows 8 docker toolbox.
Now i am able to connect and use the CMS .
My problem is my data base is not adding in the shared folder .
If i am restarting the systems all datas are going and it looks like fresh installation.
Pls help me to create data base folder .
what i did is in my c/user/xibo-docker i just put one shared folder (named shared)
but i am adding the data it is not getting saved.Is there any path to be given
pls advise
