Xibo has a database connection problem
I cannot log into my Xibo account. It bounces over to a blank white screen with “Xibo has a database connection problem.” On it. I am on Chrome via iOS, and this has never happened before.
Do you know where your CMS is hosted? It sounds like the CMS server has an issue with database connectivity. You will most likely need to log into the server itself and see by MySQL isn’t allowing connections.
