If you run a network of digital displays, you'll likely find that there are times where you might want to interact with them, perhaps to change system settings or to install software updates.
That does look slick!
Did you folks test out AirDroid? https://www.airdroid.com/en/bizHome.html
I used them for a little bit when it was in Beta… pretty slick. haven’t needed it enough to purchase it though.
Webkey looks good, I’ll need to give it a try. We’ve been using Vysor for our remote access requirements on the Andriod TV’s we have deployed, I would highly recommend the pro version which has better video qualtiy, shareable links & unlimited connections. With a one time payment of USD$40 it’s great software that is well supported.
