Xibo errors after moving t another pc
I have created a VHD file of a PC with Xibo installed and running and created the same PC from an image on another PC. Now I get errors when Docker starts:
Unable to write to the database. Exit code: 1
ב- Docker.Backend.ContainerEngine.Linux.DoStart(Settings settings)
ב- Docker.Backend.ContainerEngine.Linux.Start(Settings settings)
ב- Docker.Core.Pipe.NamedPipeServer.<>c__DisplayClass9_0.b__0(Object[] parameters)
ב- Docker.Core.Pipe.NamedPipeServer.RunAction(String action, Object[] parameters)
This is the log:
[14:14:24.450][NamedPipeClient][Info ] Sending GetDefaultVhdxPath()…
[14:14:24.454][NamedPipeServer][Info ] GetDefaultVhdxPath()
[14:14:24.461][NamedPipeServer][Info ] GetDefaultVhdxPath done in 00:00:00.0069997.
[14:14:24.466][NamedPipeClient][Info ] Received response for GetDefaultVhdxPath
[14:14:32.992][SegmentApi ][Info ] Usage statistic: actionSettingsChanged
[14:14:32.994][Notifications ][Info ] Docker is restarting…
[14:14:33.030][NamedPipeClient][Info ] Sending Restart(Docker.Core.Settings)…
[14:14:33.035][NamedPipeServer][Info ] Restart(Docker.Core.Settings)
[14:14:33.035][PowerMode ][Info ] Stop
[14:14:33.035][HyperV ][Info ] Stop
[14:14:33.035][PowerShell ][Info ] Run script with parameters: -Stop True…
[14:14:33.069][HyperV ][Info ] Script started at 14:14:33.069
[14:14:33.099][HyperV ][Info ] Module loaded at 14:14:33.098
[14:14:33.244][HyperV ][Info ] VM MobyLinuxVM is stopped
[14:14:33.249][HyperV ][Debug ] [stop] took 00:00:00.2139985 to run
[14:14:33.249][OptimizeDisk ][Info ] Optimize
[14:14:33.249][PowerShell ][Info ] Run script…
[14:14:34.865][Moby ][Info ] Stop
[14:14:34.881][PowerMode ][Info ] Stop
[14:14:34.881][HyperV ][Info ] Stop
[14:14:34.882][PowerShell ][Info ] Run script with parameters: -Stop True…
[14:14:34.903][HyperV ][Info ] Script started at 14:14:34.902
[14:14:34.934][HyperV ][Info ] Module loaded at 14:14:34.934
[14:14:34.973][HyperV ][Info ] VM MobyLinuxVM is stopped
[14:14:34.973][HyperV ][Debug ] [stop] took 00:00:00.0919967 to run
[14:14:34.974][OptimizeDisk ][Info ] Optimize
[14:14:34.974][PowerShell ][Info ] Run script…
[14:14:36.084][Moby ][Info ] Stop
[14:14:36.090][HyperV ][Info ] Create
[14:14:36.090][PowerShell ][Info ] Run script with parameters: -Create True -VhdPathOverride -SwitchSubnetAddress 10.0.75.0 -SwitchSubnetMaskSize 24 -CPUs 2 -Memory 2048 -IsoFile C:\Program Files\Docker\Docker\Resources\mobylinux.iso…
[14:14:36.104][HyperVGuids ][Info ] Installing GUIDs…
[14:14:36.104][PowerMode ][Info ] Start
[14:14:36.104][HyperVGuids ][Info ] GUIDs installed
[14:14:36.104][Firewall ][Info ] Removing all existing rules…
[14:14:36.152][HyperV ][Info ] Script started at 14:14:36.152
[14:14:36.180][HyperV ][Info ] Module loaded at 14:14:36.179
[14:14:36.282][Firewall ][Info ] All existing rules are removed.
[14:14:36.282][Firewall ][Info ] Opening ports for C:\Program Files\Docker\Docker\Resources\com.docker.proxy.exe…
[14:14:36.339][Firewall ][Info ] Opening ports for SMB…
[14:14:36.373][Firewall ][Info ] Ports are opened
[14:14:37.036][HyperV ][Info ] Using existing Switch: DockerNAT
[14:14:37.956][HyperV ][Info ] Using existing Switch IP address
[14:14:37.999][HyperV ][Info ] Setting CPUs to 2 and Memory to 2048 MB
[14:14:38.162][HyperV ][Info ] Connect Internal Switch DockerNAT
[14:14:38.320][HyperV ][Info ] Disabled Guest Service Interface
[14:14:38.336][HyperV ][Info ] Enabled Heartbeat
[14:14:38.353][HyperV ][Info ] Disabled Key-Value Pair Exchange
[14:14:38.368][HyperV ][Info ] Enabled Shutdown
[14:14:38.384][HyperV ][Info ] Enabled Time Synchronization
[14:14:38.401][HyperV ][Info ] Disabled VSS
[14:14:38.488][HyperV ][Info ] VM created.
[14:14:38.489][HyperV ][Debug ] [create] took 00:00:02.3994910 to run
[14:14:38.489][PowerShell ][Info ] Run script ‘(Get-VM MobyLinuxVM).Id.Guid’…
[14:14:38.507][Database ][Info ] Generating CA Cert Bundle
[14:14:38.527][Database ][Info ] CA Cert Bundle Generated
[14:14:38.543][DataKit ][Info ] Starting com.docker.db.exe 0.7.0-34-g6f04213 …
[14:14:38.544][DataKit ][Error ] com.docker.db.exe: Failed to set up server socket listening on hyperv-connect://8295b336-d41e-42d9-9845-e5a7e36ddfd1: Unix.Unix_error(Unix.ENETDOWN, “socket”, “”)
[14:14:38.544][DataKit ][Info ] com.docker.db.exe: internal error, uncaught exception:
[14:14:38.544][DataKit ][Info ] (Failure accept_forever)
[14:14:43.520][NamedPipeClient][Error ] Unable to send Restart: הזמן שהוקצב לפעולה הסתיים.
[14:14:43.520][Notifications ][Error ] הזמן שהוקצב לפעולה הסתיים.
[14:14:43.518][NamedPipeServer][Error ] Unable to execute Restart: הזמן שהוקצב לפעולה הסתיים. ב- Docker.Backend.ContainerEngine.Linux.DoStart(Settings settings)
ב- Docker.Backend.ContainerEngine.Linux.Restart(Settings settings)
I’m not entirely sure what you’ve done.
If I was moving a Docker-based install from one machine to another, then all I would do is install Docker on the new PC, stop the containers on the source machine, copy the installation directory over to the target machine, ensure the appropriate drive is shared in the Docker settings on the target machine, and then run docker-compose up -d
docker-compose will download the correct containers and then use the existing database/config.env file to bring the CMS back up.
