Xibo docker upgrade to 3.2.1 failed
Hi all,
When trying to upgrade to version 3.2.1 from version 3.1.5 the browser show the message:
The CMS is temporarily off-line as an upgrade is in progress. Please check with your system administrator for updates or refresh your page in a few minutes.
This is what i got from the log
Any help please.
We will upgrade it, take a backup
cms-web_1 | mysqldump: Error: ‘Access denied; you need (at least one of) the PROCESS privilege(s) for this operation’ when trying to dump tablespaces
cms-web_1 | Running database migrations
cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2
cms-web_1 |
cms-web_1 | using config file .varwwwcmsphinx.php
cms-web_1 | using config parser php
cms-web_1 | using migration paths
cms-web_1 | - /var/www/cms/db/migrations
cms-web_1 | warning no environment specified, defaulting to: production
cms-web_1 | using adapter mysql
cms-web_1 | using database cms
cms-web_1 |
cms-web_1 | == 20220906085300 ThreeTwoZeroMigration: migrating
cms-web_1 |
cms-web_1 | In PdoAdapter.php line 134:
cms-web_1 |
cms-web_1 | SQLSTATE[42S21]: Column already exists: 1060 Duplicate column name ‘lanIpAd
cms-web_1 | dress’
cms-web_1 |
cms-web_1 |
cms-web_1 | migrate [-c|–configuration CONFIGURATION] [-p|–parser PARSER] [-e|–environment ENVIRONMENT] [-t|–target TARGET] [-d|–date DATE] [-x|–dry-run]
cms-web_1 |
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/.pem’: No such file or directory
cms-web_1 | cp: can’t stat '/var/www/cms/ca-certs/
.crt’: No such file or directory
cms-web_1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
cms-web_1 | Setting up Quickchart
cms-web_1 | Removing web/install/index.php from production container
cms-web_1 | Starting cron
cms-web_1 | AH00558: httpd: Could not reliably determine the server’s fully qualified domain name, using 172.18.0.6. Set the ‘ServerName’ directive globally to suppress this message
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:56:03 +0000] “GET / HTTP/1.0” 403 2183 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:56:04 +0000] “GET /dist/style.bundle.min.js?v=3.2.1&rev= HTTP/1.0” 200 464264 “https://signage.signstop.se/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:56:04 +0000] “GET /dist/vendor.bundle.min.js?v=3.2.1&rev= HTTP/1.0” 200 3191292 “https://signage.signstop.se/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:56:05 +0000] “GET /xmds.php?what HTTP/1.0” 500 - “-” “okhttp/3.12.1”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:56:10 +0000] “GET / HTTP/1.0” 403 2183 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:56:10 +0000] “GET /dist/vendor.bundle.min.js?v=3.2.1&rev= HTTP/1.0” 206 1 “https://signage.signstop.se/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:56:10 +0000] “GET /dist/vendor.bundle.min.js?v=3.2.1&rev= HTTP/1.0” 206 848754 “https://signage.signstop.se/” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/106.0.0.0 Safari/537.36”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:57:02 +0000] “GET /xmds.php?what HTTP/1.0” 500 - “-” “okhttp/3.12.1”
cms-web_1 | 194.99.23.191 - - [28/Oct/2022:11:57:05 +0000] “GET /xmds.php?what HTTP/1.0” 500 - “-” “okhttp/3.12.1”
cms-web_1 | 62.20.80.180 - - [28/Oct/2022:11:57:08 +0000] “GET /xmds.php?what HTTP/1.1” 500 - “-” “okhttp/3.12.1”
Can anyone help still having the problem.
