Xibo Docker manual upgrade
I have an “offline” installation of Xibo so when an update comes out, usually I go with this on an online machine:
docker pull xibosignage/xibo-xmr:release_1.8.1
docker pull xibosignage/xibo-cms:release_1.8.1
docker pull mysql:5.6
docker save xibosignage/xibo-xmr:release_1.8.1 > xmr.tar.gz
docker save xibosignage/xibo-cms:release_1.8.1 > cms.tar.gz
docker save mysql:5.6 > mysql.tar.gz
Then I load the packages on the offline one:
docker load -i xmr.tar.gz
docker load -i cms.tar.gz
docker load -i mysql.tar.gz
In this way usually I can upgrade the offline installation of Xibo.
This time I have this error
Error response from daemon: manifest for xibosignage/xibo-xmr:release_1.8.5 not found
or
Error response from daemon: Get https://registry-1.docker.io/v2/: net/http: TLS handshake timeout
Wheres’ my fault ?
EDIT
I have upgraded using standard docker process from 1.8.3 to 1.8.5 so it’s not a network issue.
Something is changed from your side ?
The 1.8.5 image is called
xibosignage/xibo-cms:release-1.8.5
xibosignage/xibo-xmr:release-0.6
You should be copying the image names from the docker-compose files we publish as there’s no guarantee just the end number will change.
Perfect, it works now.
Thank you.
