Xibo CMS White Label - Example
#1
There follows a series of screenshots showing which parts of the CMS can be customised using our white label CMS theme building service.
You can find instructions on how to configure a theme for your own use here:
The following resources were used.
Logo:
Icon (in ICO format, not PNG):
Here are screenshots of the configuration inside Customer Portal. The theme was built with the option to remove the “Source” and “About” from the login page. To enable this option, the customer will need to complete an Alternative Provision of Licence form, detailing how they will meet the requirements of the AGPLv3 in the absence of those items.
Once built, a CMS was deployed on the Cloud service, and the following screenshots show the resulting CMS instance.
Login Page
If the user has not completed an Alternative Provision of Licence form, then the Source and About links from the standard CMS installation will be shown here instead.
About
Welcome Screen
Manual
Layouts
Layout Designer
Page Title and Icon
All other aspects of the CMS installation will be as they would in a standard CMS install.
Xibo CMS White Label Theme Administration
Change logo xibo
Replace the xibo logo
#2
