im trying to upgrade my docker cms to the latest version following this guide
https://xibo.org.uk/docs/setup/upgrade-xibo-for-docker-install
however the first test ( to check the library files are there ) dont appear to be writing in to the folder ,
the second test with the database backup does however work ( latest was created yesturday at 19:00).
can you please advise what steps I should now take.
