Xibo cms over https
hi
i’m using xibo on docker windows 10
i’m preoccupied with the installation of ssl
on xibo docker ubuntu 16.04 it seems so “easy” to do it why it’s not the same way on xibo docker windows 10 ?
i would like to know and understand
regards
It is slightly different because Windows and Linux are vastly different operating systems, the instructions for ssl/https on docker for windows are here https://xibo.org.uk/manual/en/install_docker_win10_64bit.html
If you’re having problems with this configuration, we’d need to know what have you done so far and where the problem is please.
