Xibo CMS is Very very slow
I installed xibo in Windows 7, but the response time is more.Sometimes it is showing blank page
Can you pls tell me the solution.
Can you tell us a little more about what you have done?
How did you install Xibo, which version, which web server, etc
I installed xibo 1.4.2, with xampp 3.2.1 in windows 7
First 1 year it works fine but now it is very slow to access
While typing URL it is showing blank page with xampp icon
After hitting F5 many times it is working.
Thanks,
Tusar
That is a useful detail :smiley:
Do you have a lot of media/layouts/schedules in the system? Have you been running the maintenance routine to regularly trim non-sensitive data?
As a start, it might be worth truncating the log, stat and bandwidth tables.
