Announcing the first patch for the 2.1 version of Xibo. This patch solves 21 issues.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/2-1-1-released/
Hey Xibo Team,
we found a Bug in the new Version.
I’ve you select a Tag and want to choose a values,
you can click anywhere else, the Tag Value Selection disapperas.
Thanks for your report.
Please can you give exact steps to replicate this and we’ll check it.
I’ve you Edit a Layout und enter a Tag, the “Tag-Value” Appear.
After this you click somewhere else than into the Value Field, the Dropdown Menu disappear.
I think that’s intended. Your tag value is set to optional so its valid to have no value set for it.
If you want to force it to have a value, then set the tag up so that its value is required.
