Xibo Client won't work on server
Hi All,
I’m facing a strange problem, I’m working with Xibo 1.7.5 if I access it via XAMPP (localhost) it seems fine apart from being slow but on an actual server only the background colour, images and videos shows and NOT the text Why ???
Sounds like you need to run Verify All from the Modules page of the CMS.
This is covered in the CMS post installation guide. You should work through that for each new server you install. It’s found at the top of the front page of the community site.
Thanks Alex I’ll try that.
