Xibo Client users will not stay logged in
I am having an issue were client users are getting logged out constantly when making design alterations to the xibo server. If they try to make any changes they just get sent back to the login page.
We have Xibo installed on a 2012r2 server, the firewall is now disabled and full access has been given to the client users to try and resolve the issue.
This has only started happening since we upgraded to version 1.8.2.
The display signage side of it works fine.
Is that a docker installation or web server?
If it is web server ie manual/custom installation you could take a look at php session time setting in php.ini perhaps (session.gc_maxlifetime)?
It’s a webserver, the session time is set to 24 minutes. The log outs happen after just a couple.
I am having the exact same issue. Has this been resolved?
I’m getting logged out between 30 seconds and 3 minutes, so it’s not a consistent timeframe either.
Web server setup, CentOS 7, this is a new install, but not looking like a longstanding install if I can’t get this to work. My session is set for 90 minutes.
I guess I should mention this is version 1.8.3.
