I was wondering if anybody could guide me here. We have the latest windows version of the Xibo Client installed on a Windows 11 Pro PC. We have simple image splash slide transitioning into a web browser slide. There is short 10 second delay between the image splash and the browser slide and then a much further delay of X minutes where it loops back on itself.
My problem is that the display somehow gets stuck on the 1st slide never transitioning to the 2nd slide. It’s only resolved when we remote connect to the display and “move the mouse”. I’m unsure of whether a local mouse movement would also resolve it at present. But there seems to be an issue where an event of some kind allows the transition to happen. Once connected remotely the problem is resolved immediately and the client transitions to the 2nd slide.
I will say that the whole process will work fine for a couple of hours then stop again.
No apparent issues in logs and status.json looks up to date etc.
Chris
