Xibo client has stopped working
Hi!, I have 2 clients, one is steady since months, with just pictures, but the other has 2 videos in loop and every day crashes, ESC and it continue for another 24 hours more or less, please help!
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: XiboClient.exe
Problem Signature 02: 2.0.0.0
Problem Signature 03: 5475e192
Problem Signature 04: mscorlib
Problem Signature 05: 4.0.30319.34209
Problem Signature 06: 534894cc
Problem Signature 07: 380
Problem Signature 08: 42
Problem Signature 09: System.OutOfMemoryException
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
So it seems that your device has not enough memory to continue the execution of a program.
Can you give us more info about your device?
Also are you using 1.7.4 versions?
Thank for your quick reply!
The version of the client was 1.7.0 beta, I downloaded the 1.7.4 and installed, up and running,
Let see if stays up !
It is a Fujitsu, p702 8 Gb ram core i3.
thank you very much!!
Luis
