Xibo client 1.4.2
Hello, I have a problems with xibo client 1.4.2 when I am on the options page. I can’t save. Can someone help me?
I’d really highly recommend to upgrade the CMS to more current versions 1.7.9 / 1.8.1.
1.4 series is over 4 years old now, a lot has changed since then.
I know, but server version is 1.4.2
Yes, you’d need to upgrade both your CMS and the player, at least to 1.7.9 version.
Regarding your issue, what does is show when you click on the ‘Save’ button?
He show nothing, nothing happends. I have register my display
I don’t remember 1.4 player, but it looks to be fine, if you start the player now it should connect to the CMS and show the content.
But the player doesn’t work
As much for me, I have sucessfull work it
Sorry for the disadvantage and thanks for the help
