# Xibo Checklist for CMS Installation
**URL:** https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482
**Category:** Get Help
**Created:** [January 18, 2017, 4:17pm UTC](https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482 "2017-01-18T16:17:24Z")
**Posts on this page:** 6
**Page:** 1
<div class="post-metadata">
### Author: ![Kendall](https://community.xibo.org.uk/user_avatar/community.xibo.org.uk/kendall/32/2427_2.png) [@Kendall](https://community.xibo.org.uk/u/Kendall)
#### Post date: [January 18, 2017, 4:17pm UTC](https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482/1 "2017-01-18T16:17:24Z")
</div>
ok I am new to Ubuntu and Xibo. most everything has been easy to follow and fix. lol for me it was not an easy install and everything that could cause problems seems to have done just that. I am using Ubuntu 16.4 and xibo 1.7.9 all checklist ticks have been completed except for 2 exclamation points on large file uploads and internationalization. I have edited the php.ini file to everything recommended and the ticker will not go away. current changes to the php. ini file include Post\_max\_size = 128M
Max\_execution\_time = 120
max\_input\_time= 120 (changed because recommended changes didn’t help)
upload\_max\_filesize = 128M
I have restarted apache2 and the complete server with no change
I have searched through documentation and found nothing related to my current problems.
on the international tick I can’t even find where to change anything. I’m sure its just because all of this is new, but just direction where to make changes would be great. I haven’t found any help or saw where anyone else had this problem.
thanks
### Author: ![dan](https://community.xibo.org.uk/user_avatar/community.xibo.org.uk/dan/32/9115_2.png) [@dan](https://community.xibo.org.uk/u/dan)
#### Post date: [January 18, 2017, 4:56pm UTC](https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482/2 "2017-01-18T16:56:38Z")
</div>
There are sections for these options in the FAQ, have you seen those yet?
[https://community.xibo.org.uk/t/xibo-cms-post-installation-setup-guide/522](https://community.xibo.org.uk/t/xibo-cms-post-installation-setup-guide/522)
> [@How do I upload files bigger than 2MB / How can I increase the upload file size limit?](https://community.xibo.org.uk/t/how-do-i-upload-files-bigger-than-2mb-how-can-i-increase-the-upload-file-size-limit/27):
> Other symptoms include an error when uploading files: SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data or simply the message true Xibo does not limit file upload size - but PHP does. You need to edit your php.ini file for your system to support large file uploads. By default, the php.ini file is in the following locations: Ubuntu (with Apache): /etc/php5/apache2/php.ini Ubuntu (with php-fpm - for example with nginx or lighttpd): /etc/php5/fpm/php.ini Wind…
> [@How do I enable Intl in PHP](https://community.xibo.org.uk/t/how-do-i-enable-intl-in-php/684):
> Windows Installing PHP extensions on Windows is easy and the php\_intl.dll extension should be bundled with the PHP installation (if it isn’t then it is likely the version of PHP you are installing is too low). There are plenty of articles giving detailed steps for this if you search for php windows php\_intl.dll, however the basic process is: Find the PHP installation, look in the ext folder and make sure the file php\_intl.dll is present In the PHP installation, look for the php.ini file and o…
If these aren’t useful in helping you resolve the issue, please let us know.
#### Post date: [January 18, 2017, 5:54pm UTC](https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482/3 "2017-01-18T17:54:30Z")
</div>
I finally found the name of the internationalized package that was giving me issues and reinstalled that to fix that problem php5.6-intl fixed that for anyone else reading. just restarted the server after and it was all good. My setup is on Ubuntu 16.4 also not windows. I think most of this came from Ubuntu wanting to use php 7. Seven will not work it must be removed and php5.6 installed back on. there are good articles on that out there.
I’m down to one exclamation point which is the large file. yes I have read all of those articles. this is on the checklist to install the CMS, so I don’t have any errors or post problems this is all still Pre requisite stuff. I still looked over that article again since you recommended it. Unless you are saying to make My setting like the ones in that article (How do I upload files bigger than 2MB / How can I increase the upload file size limit?) which isn’t like the ones on your Xibo website or the tick list recommendations, the rest doesn’t apply. instructions said do not install unless all ticks are completed. All ticks are not completed until the Large file issue is done. I’m not doing anything with a library or errors yet. I’m still preparing to install CMS. So here is where the questions come in. if I have adjusted all the php.ini file things. saved the file back to original folder and restarted the server. where is the checklist pulling from besides in that php.ini file. or what else in that php.ini file could be the problem. That is what I am trying to find out since CMS hasn’t ever been installed? What do you think?
#### Post date: [January 18, 2017, 8:00pm UTC](https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482/4 "2017-01-18T20:00:21Z")
</div>
Ok so I changed all the settings to exactly like this article: How do I upload files bigger than 2MB / How can I increase the upload file size limit?
upload\_max\_filesize=100M
post\_max\_size=100M
memory\_limit=120M
max\_execution\_time=500
This didn’t stop the Large file uploads exclamation tick either. something else is going on.
#### Post date: [January 18, 2017, 10:53pm UTC](https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482/5 "2017-01-18T22:53:03Z")
</div>
Ok I have solved all the checklist ticks now here was how I handled most of the problems up to these comments.
[http://www.cnx-software.com/2016/05/28/how-to-install-php-5-6-and-xibo-digital-signage-server-in-ubuntu-16-04/](http://www.cnx-software.com/2016/05/28/how-to-install-php-5-6-and-xibo-digital-signage-server-in-ubuntu-16-04/)
keep in mind the 5.6 install packages can not all be seen until you click on that box to get the whole list.
The large File tick problem was solved after I installed the phpinfo.php file and could see the number xibo was using. I then realized that it was pulling from another php.ini file.
the file I was editing was at /etc/php/5.6/fpm
the file Xibo pulls from is in /etc/php/5.6/apache2
when you do all the file adjustments from that php.ini file it all changes for the install.
I hope this help someone troubleshoot future problems
I am now ready to install CMS!
### Author: ![system](https://community.xibo.org.uk/uploads/default/original/2X/a/a8759c2d8cc561474733895ac75beeb830f5d8ca.png) [@system](https://community.xibo.org.uk/u/system)
#### Post date: [March 4, 2020, 5:06pm UTC](https://community.xibo.org.uk/t/xibo-checklist-for-cms-installation/8482/6 "2020-03-04T17:06:27Z")
</div>
