Xibo background white with big red X
Hello everyone!
Firstly i’ve had some amazing support from the staff here so i’m very greatful!
But i’m back with a new problem! For some reason our background disapears after a hour or so, it turns white with a big red X through it.
I’ve taken a screenshot located: gyzo link to image
Another which isn’t really important but it would help, does anyone know how i can permanently block pop ups on tvcatchup? since xibo uses internet explorer 11 the popup blocker plugin doesn’t work as good as firefox or chrome :confused:
Any suggestions?
Thanks!
-Shaun
Hello again everyone!
I’ve found restarting temparly fixes the issue, it appears to be random!
Thanks,
-Shaun
