Xibo 3.0.2 cms Debian Apache issue
Lors de l’installation, j’ai bien mis les droits sur mon dossier " xibo " installé dans mon dossier /var/www/html ( www-data:www-data + 775 )
I just install Xibo 3.0.2 and i put the folder " Xibo " in /var/www/html with " chown www-data:www-data and chmod 775 "
Once this was done, i just got an error so i tried some php version :
  • php5.6 = No access
  • php7.3 = Error
  • php8.1 = Error
I don’t know how to fix this error …
<img src="https://imgur.com/pg3aOqS">
Thanks for the help !
Update :
For patch this, i install an old version of xibo ( 2.3.13 ) and i upgrade this old version to a new version ( 3.0.6 ).
Upgrade Manual/Custom Install | Xibo Open Source Digital Signage
All is fine now.
