Xibo 1.8 webpage opening unable to edit design
When a web page is setup, i.e. to display weather conditions, once you navigate to design or edit after a few second the web page is opened in the browser and you are then unable to edit the design. i have not found a way once the web page is added to the design, to then edit the layout. what am i missing?
I’m not certain what is the issue, could you export your layout and send it to me over private message please?
Even if you have webpage widget on your layout set to best fit / manual position which will show the webpage in the designer it certainly should not prevent you from editing the layout.
It would be also good to know which CMS version are you using please?
will do, thanks for your time and help, should have the export shortly.
looks like i am unable to send a message, i have only been a member for a few hours. any suggestions?? can you message me, so i can then reply please…
Any insight into how to remove the website,. possible to receive a export of a default layout?
