Xibo 1.8 Library
hello , I just installed xibo 1.8
and I got stuck when entering the library name
/var/www/xibo/library
unable to write on the server
any idea
Sounds like a permission issue. Looks like you are running on linux. Does the user the Apace web server is running as, have read write access to the library folder? (Assuming you are running Apache)
sorry I forgot to mention im Using Vagrant on windows
Not familiar with Vagrant, but it looks straight forward, Can you tell me what web server you are running? Also the user name the web server it is running as? As I think you just need to give the web server permissions to read and write to the library.
