Xibo 1.8.2 iis probleme mise en page acces web
Bonjour, suite à l’installation en manuel de la version 1.8.2 sur iis. Le site ne comporte plus de mise en page.
Voir capture d’ecran.
D’où cela peut il venir?
Merci
Could you check documentRoot and URL rewriting configuration please, see notes here (if you’re not using docker) http://xibo.org.uk/manual/en/install_environment.html
Is this a fresh 1.8.2 installation (could be good to know more about your environment as well) or is it upgrade from previous versions?
thank’s for you help, i resolve the problem with the doc. i change rule rewriting in the web.config by rule indicate in the manual.
