Xibo 1.8.0 Scrolling with Next and Prev in the calendar
Scrolling with Next and Prev in the calendar often does not work. The gear remains rotating and nothing is displayed. More than 10 minutes.
It seems to work correctly on our CMS Instance.
Actually since I have access to your CMS as well, I tried it there and it seems to work for me on your CMS just fine.
Could you please tell me what browser are you using?
Did you try to clear the cache perhaps?
Please try it in the year view. From 2017 to 2018. Problem with Google Chrome and Firefox.
[quote=“Peter, post:2, topic:9414”]Did you try to clear the cache perhaps?
[/quote]
yes
Well, it works fine on my local CMS and on our Cloud, but indeed with displays selected when you change year on your CMS it can’t load it correctly, the errors in the chrome console are:
I’m not sure why that is, @dan when you got a moment have a look at this please.
