My CMS scheduler does not show the schedule after 21:30.
Even scrolling down will not let the page go down below 21:30.
Is there any setting page for this?
What’s the first time shown at the top of the day?
Strange. My 1.7.9 install here shows 00:00 - 23:30 as expected.
Is the CMS timezone the same as the server it’s running on?
Yes, I checked timezone setting of the server(virtual machine), the physical server, and
the CMS, but all the settings are the same.
php.ini setting was also correct…
I tryied on chrome, Fire Fox, IE, but the same issue happened on all the browsers…
I seem to recall that this was an issue in a earlier release of 1.7 - are you sure you have 1.7.9?
Hi, Dan
I found my CMS version is 1.7.1.
It seems this is because of the issue of the older version you mentioned.
I will try updating CMS to 1.7.9 first.
Thank you!
Hi, Alex, Dan
The problem has been solved by updating to 1.7.9.
Thank you so much!
