XIBO 1.7.7 can't add users nor Layout
Hi all,
I just finished installing Xibo CMS 1.7.7 successfully on Windows 10E 64.
Using Google Chrome, IE or Firefox on the same PC or from remote system when I click to add users or Layout nothing happens.
Any idea why?
Thanks for any help.
Abi
mmm no, but if you can enable debugging (Report Fault page in CMS) and then recreate the issue and check if there is anything interesting in logs, well then we might know more.
If you intend to upload troubleshoot.txt (log file) here, please keep in mind that it may contain some sensitive data about your CMS, so you might want to edit that out before uploading it here.
Never mind.
It was user permission issue.
All fixed now!
Thx
