Installation Method
Docker Toolkit
Operating System
Windows Server
After updating to the latest Xibo release from 2.0.3, I have noticed that any html/PHP files that I have inside of the userscripts directory, are having a new response header with X-Frame-Options added. This doesn’t work for our setup, as some of these html/php files are embeded in my layouts using iFrames. This is all of my content, and not external. Is there a way to change/remove the X-Frame-Options out of the header for any hosted content inside of the userscripts folder?
Thanks!
