Player won’t download UHD images. Has no issues loading up to FHD (1920x1080) images.
Repro
Create a 4k UHD layout.
Assign a UHD (3840x2160) background image.
Player will download all content except for the image.
Player will emit the following error “MainForm - PrepareLayout Unable to set background: C:\XiboLibrary\47.jpg”
When checking the display’s media, the UHD image is never downloaded. It just sits there forever.
This probably isn’t something specific to the Windows Player - rather the CMS settings might need some adjustment.
There is a image size limit and a resize threshold which you can configure in CMS settings which determines the maximum sizes of images that will be sent out to Players.
The little cogs in your screenshot mean that the image uploaded is waiting for resize - meaning it triggered one of those limits.
I should also note that everything shows up in the layout designer just fine and the layout reports ready, I know it usually tells you when it’s doing some image resizing for the layout.
Pretty sure XTR is running. CMS is installed on Ubuntu via Docker v2.3.
I can remember having some other images resize and load with no issues but they were not full UHD.
I’m going to try removing the hung media and re-upload it since I updated the resize settings after the media was loaded and see if that resolves the issue.
Removing the UHD image and re-uploading resolved the issue with the change in the image resizing settings. The player loaded the UHD images with no issue.
