Windows 10 Powerpoint problems
I have been tasked with trying to find out if we can get Xibo working on a Windows 10 machine - having tested this, I am having difficulties getting Powerpoint Presentations to work.
I used the below information to get it to work properly on a Win7 machine - but have had no luck so far with Win10 - I have installed only Powerpoint viewer on the Win10 - Will it only work with the full Powerpoint program?
http://xibo.org.uk/manual/en/media_module_powerpoint.html#machine_preparation
Most likely, yes.
If you don’t want to / can’t install it, perhaps try the option 1? ie export the presentation as a video and put it in a video module in Xibo.
