Widgets oversized when designing layouts
Hi everyone!
I have a problem with the CMS (we have recently updated it to version 2.3). When I am in the designing mode, I see all the widgets I add to the regions oversized, but in the preview I see them with the correct size. Anyone with the same issue?
Example (background image + subplaylist with text):
Same layout in preview:
Thanks!
This is most likely down to your browser caching an old copy of the Xibo JavaScript - can you please try clearing your cache and reloading the page?
Also - nice sun loungers!
Also, note that the widget appears to be the proper size; it’s the contents that are too big…
Hi @dan,
I’ve tried clearing the cache and even with another browser but nothing has changed. Could it be something else?
I’m glad you like the sun loungers! hahaha It’s a hotel in our beautiful Mallorca :slight_smile:
Thanks!
Very odd - I am not able to recreate the issue.
I wonder if the upgrade didn’t correctly upgrade the Module files - can you try:
  • navigate to administration → modules
  • click “Verify All” from the top right, and then verify
  • find “Text” in the list, use the row menu to select “Clear Cache”
  • see if that has helped
Ah, i’d much rather be there! haha :beach_umbrella:
That’s it! It got fixed after clicking “Verify All”
Thanks a lot, @dan !
