Hi, I’m using 2.2.2, and I’ve created a layout called Melt.
In the image above, the animated gif in region two as well as the weather widget in region 3 do not appear on my computer (Windows 10), but the preview in Xibo works just fine. Region 1 layer is 0, region 2 is 5, and region 3 is 10. I’ve tried deleting and recreating the layer altogether without any luck. On the test PC, I’ve gone into Documents, moved all data into a newly created folder called old, and then redownloaded my contents; the result is the same using the newest client. On the test client (W10), my background and text from region 1 loads without a problem.
I have a ZIP ready with my project contents, so PM me, and I’ll send them over. Thanks again for all your help.
