My xibo player start to blinking after a few min. Need your help
Can you provide more information about the issue? For example:
- Which version of the Player are you using?
- What is blinking? Is it the Layout, whole Player or the device itself?
- What version of the Xibo Player are you using?
- Are you receiving any errors? You can check this in the Log option on your CMS and the Status Page on the Player itself.
