White lable resller
Hi, Instead of monthly based subscription do you have “one time payment” option for Server and Client as a white label reseller?
Short answer is no.
In normal use, CMS cloud hosting with Spring signage is billed annually.
Monthly billing for cloud instances can be enabled.
The White Label services have nothing to do with it, they are for branding which does not affect hosting price.
Clients on the other hand
Windows client - it’s distributed under AGPLv3 open source licence - free to download and use.
White Label service here is per version.
Android client - commercial player, £15 Xibo for Android licence required per device - one time cost / per device for the major version you buy.
White Label service here can be updated to newer version without additional cost.
