When I looked at the log, two errors were displayed. Could you please tell me the cause and how to deal with it?
・Thread Woken and Lock Obtained.
・Layout has invalid dependent: 738.mp4.
Japanese Version
このメッセージは、738.mp4 というファイルに問題があり、正しくアップロードされなかったか、CMSライブラリ内で利用できなくなっている可能性があることを意味しています。レイアウトでどこで 738.mp4 が使用されているか確認し、その後ライブラリでそのファイルが存在するかを確認してください。もしファイルが無い場合は再度アップロードし、レイアウトに再度割り当ててください。もしファイルが存在する場合は、一度レイアウトから削除してもう一度追加し、リンクを修正してください。この操作後もメッセージが出る場合は教えてください。
Hi, the message means that the file 738.mp4 likely has an issue and was either not uploaded correctly or is no longer available in your CMS library.
You should check your layout to see where 738.mp4 is being used and then check your library to confirm if the file is there.
  • If it is missing, upload it again and reassign it in your layout.
  • If it is still there, try removing it from the layout and adding it back to fix the reference.
Let me know if the message stays after trying this.
Please share the exact error messages from the log—that’ll help identify the cause and suggest a fix.
Can you identify which file is 738.mp4?
This is a video that you or someone with access to your CMS has uploaded. Look in Media/Library - You can also look in the library folder on the client / player and see if it has been downloaded completely
Alternatively, you can retrieve the information by using the API with the mediaId parameter:
http://example.com/api/library?mediaId=738
If neither approach works, you can try deleting the entry for that media file from the xibo MySQL db via command line or the windows gui tool . I’d delete the layout and recreate it afterwards
“Check the log errors carefully and troubleshoot safely avoid relying on sites like ‘spotimody.com.’”
