Websites view as Mobile versions rather than Desktop versions
When I link a website in to a region it views fine in my preview browser, but when it is viewed on our tv display through a Minix Android it views as a mobile site. Is there a way to overwrite this so it will display the Desktop version of the website? I know that in the browser settings on the minix you can request desktop sites to be displayed, but I see no such option in the Xibo app.
Do you use embedded module or webpage module?
What apk version do you use?
I am using Webpage module, and the APK version is 2.9.05. I think.
Xibo will already request the desktop version of the website - if you are seeing the mobile version it probably means the website is doing something odd to detect the browser.
You could try using “Manual Position” and setting the appropriate width for your region
