When viewed in Chrome on the Xibo player PC (Just a PC on a Stick plugged into a 60" 4k display) it displays perfectly, however when using Xibo to display it in a web region it randomly drops off text and banners and other elements. I have tried all the different display types (natively, manual, best fit) and none seem to make a difference.
The region is 1080p. It looks to me as though it’s running out of memory and dropping the frames/not loading properly.
It appears to hang in IE on my computer as well. In Chrome, it works with no issues. Can I change which browser it uses?
I have thought about using embedded HTML instead of a web region, but that would require a lot of extra work on my behalf. I’ll start tinkering with that on my end and see if I can come up with something.
Thanks,
Alex
EDIT: Sorry, forgot to add the CMS version. I’m on 1.8.9 and the display is on 1.8.3
