Webpage Xibo 1.8.1
Hello Community!
i tried to display a webpage in a widget but it does not show.
Here are some screenshots.
what am i doing wrong?
In 1.8.0 it worked perfectly.
It will not be displayed in the layout designer when it’s set to ‘Open natively’, it should be displayed in the preview and on a player though.
If you want to see in the designer you’d need to change it to best fit or manual position.
