I try to add any webpage (http://google.com) on default layout, but i dont see anything but the black background in preview
Somebody could help with this?
Thank you
Thank you
At a guess, your CMS is accessed via https then if you add a webpage accessible via http, it will not display it in the browser, however it should work fine on the player.
Alternatively, perhaps google.com can’t be displayed like that for some reason, should still work in the player though.
Can you try for example https://springsignage.com/ ?
Yes that’s it !
I dont see on the CMS Console but in the Client its all good
Thank you !
