Webpage loading too slow. not like usual
Version 2.3.16
Installation Method
Custom install
Operating System
windows server 2019
taking too slow to load and to connect player to cms. for the first 2 months, all is good. but now become slow and not like usual. can u help me to know what the cause of this problem ?
please help me sir @alex thank you
It’s a custom install and we don’t support those, so no I’m afraid I’ve no idea what the problem is. You’ll need to look at it from first principles - so look at what process is making it slow? Is it PHP, is it the database etc, and then look at what that process is doing more than normal.
If you have graphing then looking at that before and after the problem started will be a big help.
Good luck!
