Web Page in campaign
I have a problem to display web page in campaign.
As I can see, there might be the problem, because the status of the web page layout is “There are items on this layout that can only be assessed by the display”.
I have to say that if I use this layout as Default Layout there is no problems.
Is there any workaround for this.
I’m using CMS Version 1.7.5.
Thanks.
It’s not a problem, you probably have your webpage item set to open natively, which means it will be opened in your device’s native browser - that’s all that means.
If it works as a single layout it will work in campaign as well, campaign is an ordered list of layouts.
You might want to also upgrade your cms/player to 1.7.7, but it should be fine on 1.7.5 as well.
