Weather Widget - Carrier return
Hello everybody !
Could you please help me to tweak the weather widget !?
I have 2 wheather widget in my timeline with 2 different offset ; the first one is for the current day, the second one for the next 6 days ==> [dailyForecast|6|1]
To make it fit my region properly, I want to display 3 days on a line, and 3 days on other line, by default all days are on the same line
Thanks in advance for your help !
I finally found the trick :slight_smile:
Just change the <div class="col-xs-2 upcoming-days shadowed"> to <div class="col-xs-4 upcoming-days shadowed">
Perfect result for me
