Weather module : size of widget
Hi
I am testing the weather module. Getting data is ok.
there is a field to match the size of the widget into the region.
changing anything in this field does not change anything in the appearance.
what is wrong?
In 1.7 series, it just doesn’t work very well I’m afraid.
The weather widgets have all been reworked for 1.8 series, so they resize to fit your region properly.
ok, I just downloaded 1.8 for Server and Client and will test this Weekend
Thank you
1.8.0-rc1 is released for testing purposes. You are welcome to test with it, but we don’t recommend it for production use yet.
