in spite of my setting the weather language to “Deutsch” I get words like humidity…
seems that only text entries are in correct german, but not units and so on.
this is not so hard to see, most of the units are not used, but I want to get directions like O for “Osten” and not E for “East” and the wind is blowing in kmh here instead of mph.
Some of the Elements in your Weather Template, such as Wind and Humidity, will appear in English as they are part of the template itself.
You can change these elements of your Template by Editing your Weather Widget within your Layout, select the Appearance tab and tick the Override the Template box. Below are screenshots showing how I did this:
This is how Template 13 appears when set to German:
